I have checked and found no clogs; any other ideas?
Can you be more specific on the problem? What is the complete model number of the dishwasher?
Originally Posted by: Gene  I'm glad you were able to fix it.
Hi Gene,
I had this problem draining and cleaning the one way valve fixed me right up. I just wanted to say thanks! :D
Brian
PS For anyone else doing this, the rubber valve flops outwards. It took me a while to figure out you can run a long screw driver right through the valve to clear the blockage, just do it from the small diameter exiting through the large diameter.
Hello Gene,
Thanks for the advice on the check valve, I couldn't let this thing whip me and low and behold I found 2 fish bones and 2 lemon seed stuck inside. Pumps like it should now. Thanks a bunch once again Gene!!!
I have the same problem with my DU920PWKQ0. I have cleaned the check valve and hose. I ran water through the check valve and it flowed fine. It's still leaving about an inch of water left after cycle done. I have gotten all the water to drain out but had to run drain cycle 4 or 5 times. I don't know where to go next. Can you help?
Originally Posted by: SMarten  I have the same problem with my DU920PWKQ0. I have cleaned the check valve and hose. I ran water through the check valve and it flowed fine. It's still leaving about an inch of water left after cycle done. I have gotten all the water to drain out but had to run drain cycle 4 or 5 times. I don't know where to go next. Can you help? Where is the drain hose connected to? If it's connected to the garbage disposal, disconnect it and check for any clog. Make sure there is no any floating foreign objects inside the hose. If it's connected to the air gap on top of the sink, most likely the air gap is clogged up. Gene.
