I have a dryer it starts and lights flame but after 30 seconds goes out then it just keeps running. I think it maybe the coils but is that all I need ?
If the igniter continues to cycle on and off, the most common failure is the coils. Then, it can be a weak igniter. Part number: AP3094251
Originally Posted by: magician59  If the igniter continues to cycle on and off, the most common failure is the coils. Then, it can be a weak igniter. Part number: AP3094251
Thanks for the help magician59 I
Magician59 I will let u know if that works. I have ordered coils and thermistor the ignitor seems to lite fine continuity good but i should get parts by wed so u will here from me then.
