I installed part # WD21X10247 (Kit Main & Tactile Board) . It beeped until and Clean light flashed. Beep would stop after pushing Start button. Clean light continues to flash. That's all it does. Nothing else. Your company graciously sent me another board thinking the first may have been faulty. Installed it, same result.
I was wondering if there is some sequence of buttons that need to be pushed to activate it? Originally a repair man confirmed the original board was blown out,(no power or lights), so I can confirm there is power on the new board, just won't do anything, but flash a Green light on Clean.
Any suggestions? Thanks,
Originally Posted by: kentburns2008  I installed part # WD21X10247 (Kit Main & Tactile Board) . It beeped until and Clean light flashed. Beep would stop after pushing Start button. Clean light continues to flash. That's all it does. Nothing else. Your company graciously sent me another board thinking the first may have been faulty. Installed it, same result.
Any suggestions? Thanks, Kent, We apologize for the delay in our response, Have you checked or replaced your door latch / switch assembly ? Here are possible parts needs, and an excerpt from the Service Bulletin that pertains to your machine and possible problem. Part number: AP4333997
Part number: AP3872949
( 2 needed) Part number: AP3872943
Part number: AP4334006
Malfunctioning interlock switches will cause a variety of customer complaints including: • “Clean” light does not turn off • Dishwasher stops in mid cycle • Dishwasher stops in mid cycle and beeps • Dishwasher operation is intermittent • Dishwasher stops, then restarts while the door is latched • Dishwasher will not start • Control panel does not respond to input when the door is latched These conditions can be traced to interlock switches that open or remain open when they should be closed. As a result, the control thinks the dishwasher door is open and therefore will not run. Resolve the customer’s issue by repairing the mechanism that operates the switches. Refer to Service Bulletin DD 01-06 for a discussion of the switch and plunger assembly. DD 01-06 advises the service technician to replace the switches and plunger/spring assembly if the plunger sticks when slowly depressing or releasing the plunger. It also advises adjusting the latch keeper to fully depress the plunger if it is not doing so. If the plunger operation checks out okay, replace the interlock switch cover, part number WD12X10194. The cover design has been modified to better position the interlock switches. It went into production in February 2007 as a running change and is completely backward compatible.Good Luck,:) :) :)
