I have a Kenmore HE4 dryer that won't start. The display lights won't turn on but the inside light in the tub turns on when the door is opened. I have confirmed that the outlet is getting the proper voltage to the dryer. The only thing I can guess it might be is the circuit board that the power goes into or the circuit board behind the display. Any other suggestion for things to check before I purchase a new circuit board?
Originally Posted by: bartj ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Kenmore HE4 dryer that won't start. The display lights won't turn on but the inside light in the tub turns on when the door is opened. I have confirmed that the outlet is getting the proper voltage to the dryer. The only thing I can guess it might be is the circuit board that the power goes into or the circuit board behind the display. Any other suggestion for things to check before I purchase a new circuit board? There will be a thermal fuse mounted on the vent tube. That will most likely be your culprit. Tom ApplianceEducator.com
I'll give that a try. Thanks.
Originally Posted by: kayakcrzy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There will be a thermal fuse mounted on the vent tube. That will most likely be your culprit. Tom ApplianceEducator.com Tom I need your help I need more parts. thank you for all your help. Great Guy.
