bfurst
#1 Posted : Thursday, November 11, 2010 7:23:12 PM(UTC)
bfurst
there is a humming noise when the compressor tries to start and then the internal circuit breaker pops. after several tries it finally starts and cools fine. the only other thing I see is that there is condensation on the outside back of the freezer. any ideas? thanks
#2 Posted : Friday, November 12, 2010 1:27:12 AM(UTC)
I would replace the compressor start device behind the compressor side cover. Order AP4009662. It's possible the device is going bad, or you have a burnt wire there. If that fails to start it, you have a hard starting compressor that would have to be replaced.
bfurst
#3 Posted : Friday, November 12, 2010 3:46:27 AM(UTC)
bfurst
one more thing I found is if it is unplugged for about 10 min. when you plug it back in it starts right up and runs. does this make help ?
#4 Posted : Friday, November 12, 2010 3:22:17 PM(UTC)
Seems like you just have a hard starting compressor, new start device might not fix this, but worth a try.
