mike500
#1 Posted : Friday, November 12, 2010 10:36:25 AM(UTC)
mike500
My dryer would stop in mid cycle, then after pressing the start button a few times it would start back up, eventually it would not start at all. after replacing the motor I pressed the start button and herd a hum but no start. Now when I press the start button there is no hum.
magician59
#2 Posted : Friday, November 12, 2010 11:17:33 AM(UTC)
magician59
The first place to start checking is the power source. Do you have 240VAC (or somewhere near that) at the outlet? At the terminals where the cord connects to the dryer? Does the light come on when you open the door? Press in on the door switch with the door open, as you try to start the dryer.
Does this happen in all the drying cycles? Let us know what you find.
mike500
#3 Posted : Friday, November 12, 2010 11:42:22 AM(UTC)
mike500
Thank you so much for responding. THe power outlet did read around 240. there is no light. and this happens every cycle. when I put the new motor in and pushed the start button the dryer hummed and the house lights got dim. now absolutely nothing happens.
mike500
#4 Posted : Friday, November 12, 2010 11:49:37 AM(UTC)
mike500
the meter read around 230 at the terminals.
magician59
#5 Posted : Friday, November 12, 2010 12:55:38 PM(UTC)
magician59
You definitely have a locked motor. It could be the motor itself is bad; maybe something jamming the blower fan; or maybe the belt is threaded wrong or tensioned wrong.
You'll need to open it up and see. Hopefully your new motor isn't damaged.
Maytag Dryer Not starting (Dryer Repair)
by icetea07 5/31/2017 12:54:26 PM(UTC)
dryer not starting (Dryer Repair)
by DConway0005 3/16/2017 3:40:22 PM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Help! GE dryer not starting (Dryer Repair)
by lelidi 2/4/2015 9:04:46 PM(UTC)
Dryer Not Starting (Dryer Repair)
by dellarte 1/5/2015 5:03:30 AM(UTC)
Maytag Maxima dryer not starting (Dryer Repair)
by ssolle 12/29/2014 8:13:27 PM(UTC)
Dryer not starting (Dryer Repair)
by kbeealexander 6/7/2014 5:59:58 AM(UTC)
by Matt18 11/26/2013 9:56:49 AM(UTC)
by rberger3 10/23/2013 7:34:39 PM(UTC)
Kenmore dryer not starting (Dryer Repair)
by Frustratedinal 5/11/2013 6:18:59 PM(UTC)
Whirlpool Gold gas dryer not starting... (Dryer Repair)
by arvydas512 3/12/2013 10:43:01 AM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Gibson gas dryer not starting (Dryer Repair)
by tad.m 1/31/2013 1:26:02 PM(UTC)
Need help with old Maytag dryer not starting (Dryer Repair)
by momkaren 9/7/2012 6:51:36 PM(UTC)
