valdiviesochicas
#1 Posted : Thursday, November 11, 2010 1:52:41 PM(UTC)
valdiviesochicas
My dishwasher washes perfectly, but most of the time it keeps filling up with water after it is done working. Somedays it won't but mostly everyday. Thank you.
magician59
#2 Posted : Thursday, November 11, 2010 2:00:22 PM(UTC)
magician59
You may have a failing water inlet valve. It is solenoid-activated. If the valve is clogged with debris (scale, rust, etc), the solenoid may not seat tightly enough to keep water from dribbling through. If this is the case, it is a flood hazard.
valdiviesochicas
#3 Posted : Thursday, November 11, 2010 2:05:29 PM(UTC)
valdiviesochicas
how do I fix this problem
magician59
#4 Posted : Friday, November 12, 2010 5:03:01 AM(UTC)
magician59
Here's the part. It's located under the dishwasher, accessable behind the toe plate (tight fit). Turn off water supply before working on it.
Part number: AP3783031
Bosh dishwasher got E15 error. Found leak (Dishwasher Repair)
by Kh0456 1/1/2021 8:47:31 AM(UTC)
Bosh Dishwasher SHE3AR75UC/22 runs for 3 minutes, and then stops. (Dishwasher Repair)
by wcking 11/11/2018 10:57:57 AM(UTC)
Bosh dishwasher makes noise unplugged (Dishwasher Repair)
by Gabor_in_AA 9/19/2013 5:11:13 AM(UTC)
Stench from my Bosh Dishwasher (Dishwasher Repair)
by danimal1972 10/13/2009 11:33:39 AM(UTC)
Bosh Dishwasher noise (Dishwasher Repair)
by phayburnsr 12/20/2007 12:34:08 PM(UTC)
