csynowie
#1 Posted : Wednesday, November 10, 2010 8:53:36 AM(UTC)
csynowie
I don't know anything about repairing a dryer. I know we need a thermostat, but did not realize there are 3. Can anyone help me determine which one I will need?
magician59
#2 Posted : Wednesday, November 10, 2010 9:09:27 AM(UTC)
magician59
What symptom(s) led you to conclude that you need a thermostat? What are the first three digits in the model number, before the "dot"?
csynowie
#3 Posted : Wednesday, November 10, 2010 9:15:19 AM(UTC)
csynowie
110 We had to get the thermostat replaced twice before. both times the dryer just stopped heating.
magician59
#4 Posted : Wednesday, November 10, 2010 10:23:16 AM(UTC)
magician59
Most of us, as a rule, replace all the thermostats, if one is bad. But there is usually an underlying cause of an open thermostat. The most common cause is clogged or restricted air flow. Make sure the exhaust vent is clear, from the dryer to the outside of the house.
Does the motor run?
Also, "No Heat" can be a result of an open or burned out element.
csynowie
#5 Posted : Wednesday, November 10, 2010 10:45:02 AM(UTC)
csynowie
thank you. i think this is beyond my fixing. I will call the repairman.
magician59
#6 Posted : Wednesday, November 10, 2010 10:49:57 AM(UTC)
magician59
No shame in that. Let us know how it goes.
Which thermostat connectors do I test with ohm meter? (Refrigerator & Freezer Repair)
by topfreeze 12/10/2010 1:30:05 PM(UTC)
Which Thermostat Do I need (Dryer Repair)
by pingeye2 10/7/2008 9:52:51 AM(UTC)
