jic811
#1 Posted : Wednesday, November 10, 2010 6:01:41 AM(UTC)
jic811
Got latch w/ handle assembly and how to replace? Is there something to look at. Does entire door come of?
magician59
#2 Posted : Wednesday, November 10, 2010 6:18:24 AM(UTC)
magician59
No need to remove the door. Just open the door and remove the screws (Torx T-15) around the inside perimeter, that hold the inside panel to the door. It will come off to expose the latch, electronics, and vent area. It should then be obvious how the latch is attached, and its relationship to the door switch assembly.
Joe / APP Team
#3 Posted : Wednesday, November 10, 2010 6:27:43 AM(UTC)
Joe / APP Team
JIC,
You don't need , or want to remove the complete door.
Of course you are going to turn power off the the dishwasher, first thing.
Open the door , and remove all the screws (10) holding the plastic liner to the door panel, you can then use the interior metal door brace as a prop rod to hold the door down, while you work on it.
Most repairmen, find it easier to install the latch assembly on the door catch strike,on the tub, in order to install the handle into the latch assembly.
Once you've got the handle installed on the latch, switch your wires from the original latch to the new latch, then reverse procedure and test the latch and operation.
Good Luck,
:cool: :cool: :cool:
jic811
#4 Posted : Wednesday, November 10, 2010 6:38:37 AM(UTC)
jic811
Thank you. Did and have pulled and cannot get the connect on each side loose. I have pulled and will not come off.
jic811
#5 Posted : Wednesday, November 10, 2010 6:40:53 AM(UTC)
jic811
Originally Posted by: Joe / APP Team Go to Quoted Post
JIC,
Good Luck,
Thanks but cannot get wires off. ????
jic811
#6 Posted : Wednesday, November 10, 2010 6:58:27 AM(UTC)
jic811
Got it done. Works. Thanks!
jic811
#7 Posted : Wednesday, November 10, 2010 6:59:34 AM(UTC)
jic811
Thanks, got done works!
magician59
#8 Posted : Wednesday, November 10, 2010 7:12:02 AM(UTC)
magician59
Well done! You saved yourself a little over $100.00
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
by Guest 10/20/2022 10:23:08 AM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Maytag dishwasher, cancel button (Dishwasher Repair)
by jtt21 6/28/2022 5:24:58 PM(UTC)
Maytag dishwasher quiet series 300 (Dishwasher Repair)
by Guest 6/12/2022 7:04:36 PM(UTC)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 5/16/2022 9:37:56 AM(UTC)
Maytag dishwasher MDB4709AWW1 (Dishwasher Repair)
by dkmc1953 3/6/2022 1:13:12 PM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Maytag Dishwasher Making Clanging Noise Even When Empty (Dishwasher Repair)
by gtg931 12/20/2021 7:13:20 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
Maytag dishwasher MDB4949SDZ0 (Dishwasher Repair)
by tonygm 5/29/2021 1:47:18 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Maytag dishwasher fills, then drains (Dishwasher Repair)
by vtfireman85 3/12/2019 7:30:34 PM(UTC)
