BikerWoman
#1 Posted : Tuesday, November 9, 2010 8:37:50 AM(UTC)
BikerWoman
Is there any problem with removing the water pump from my washer (HE3t) while the gas Dryer (HE3) is stacked on top of it? Any reason why I should not stack them?
Initially 02 code, cleaned filter but suspect other problem as there is sporadic clunking and stopping of the drum when it is turned by hand.
#2 Posted : Tuesday, November 9, 2010 2:50:41 PM(UTC)
The water pump should be accessible from the front and I don't see why you can not stack the dryer on top of the washer if they are specifically designed to be stacked.
BikerWoman
#3 Posted : Tuesday, November 9, 2010 2:55:03 PM(UTC)
BikerWoman
It wasn't that I can't get to it, it's more a stability question. Are there any repairs, other than opening the top, that should not be done with them stacked (again stability issue)?
BikerWoman
#4 Posted : Tuesday, November 9, 2010 2:56:02 PM(UTC)
BikerWoman
By the way, thanks for answering!!
#5 Posted : Tuesday, November 9, 2010 3:43:08 PM(UTC)
You are welcome.
If the dryer is properly installed and mounted on top of the washer then there is no worry about stability.
BikerWoman
#6 Posted : Tuesday, November 9, 2010 5:49:22 PM(UTC)
BikerWoman
THANK YOU again for your help. You are saving this DIYer lots of money, which is really appreciated (I've been out of work 2 years as of yesterday).
I believe I either have something between the tub and basket :cool: or a bearing is going out :(. Going to remove the back, pulley and belt and see what the problem is. Anything special about replacing the bearings -- I have a Timken bearing supplier in town--so if I have to go that route, I'd rather be ready.
Thanks again!!!
