FEVER
#1 Posted : Tuesday, August 12, 2008 12:11:03 AM(UTC)
FEVER
My dryer takes a long time to dry my clothes, I hear something click on
and off as it is running and it doesn't get very hot, is it possible it is a thermostat or could it be that one of the high or low regulators is bad
#2 Posted : Tuesday, August 12, 2008 1:59:13 AM(UTC)
I would run it without the attached ducting and see if it now works ok. If so, you need to clean your ducting. If a long run, you will need a "Lint Eater brush".
They probably have it at this parts site, just call.
FEVER
#3 Posted : Wednesday, August 13, 2008 8:24:12 AM(UTC)
FEVER
Thanks, I've looked at the vent and it is all clear, is there any ideas
you may have.
abadfish66
#4 Posted : Wednesday, August 13, 2008 9:11:05 AM(UTC)
abadfish66
With the dryer running go outside and make sure you have good airflow out the vent. Also take the vent off from the wall, and take a temp reading of the exhaust air with the dryer running. Should be around 180 degrees and when the heat stops, you should lose about 1 degree per second.
Whirlpool LP gas dryer-Blackish color in drum (Dryer Repair)
by clevenhagenjs 2/2/2013 8:16:36 PM(UTC)
No Heat in Kenmore series 80 LP Gas Dryer (Dryer Repair)
by ademing 10/8/2012 2:56:46 PM(UTC)
