JME
#1 Posted : Monday, August 11, 2008 2:18:25 PM(UTC)
JME
The condenser fan does not run when compressor starts and alot of heat builds up on the parts. If I spin the fan blades manually the fan starts running. Does this sound like the motor of the fan is bad or is there a thermostat that starts the fan that could be bad?
abadfish66
#2 Posted : Monday, August 11, 2008 3:25:00 PM(UTC)
abadfish66
The motor is bad, here's the part# AP3184264
JME
#3 Posted : Monday, August 11, 2008 3:26:06 PM(UTC)
JME
thanks so much. Jim.
Freezer not freezing/Condenser fan not running. (Refrigerator & Freezer Repair)
by lerainking 6/23/2011 6:36:16 PM(UTC)
