The condenser fan does not run when compressor starts and alot of heat builds up on the parts. If I spin the fan blades manually the fan starts running. Does this sound like the motor of the fan is bad or is there a thermostat that starts the fan that could be bad?
The motor is bad, here's the part# AP3184264
