judbgrdmchn
#1 Posted : Saturday, November 6, 2010 2:05:44 PM(UTC)
judbgrdmchn
I am leaking oil from the gearcase where the shaft comes out horizontally and connects to the electrical rotor thingy by means of some plastic & rubber gear/cog thingies. I took the gearcase to my trusted parts store and was sold a pack of 2 oil seals. However, where the shaft comes out is too large for them to fit. There is a plug of some sort there but i can see no way of removing it.
The question is, do I have to go into the gearcase to change the seals or was i sold the wrong part & the actual part I need is the larger plug?
Here's the appliance parts pros link to the diagram. The oil is leaking from the plug at number 21. Gearcase replacement parts for WHIRLPOOL LA9500XTN0 | AppliancePartsPros.com
ThatGuy
#2 Posted : Sunday, November 7, 2010 4:32:35 AM(UTC)
ThatGuy
Groups: Expert
You have been a member since:: 7/27/2010(UTC)
United States
One of those seals should be the right one. I go by the diameter of the old seal. It should fit tight on the input shaft. Use a drop or two of oil to help it slide on after you remove the old seal.
The way I usually do it is to set gearcase on its back and brace it, so the input shaft is facing up. Use a o-ring pick to pull the old seal out or use a small screwdriver. Once its out clean the shaft and slide the new seal on, tapping it flush to the housing with a suitable piece of pipe or a socket the same diameter as the seal.
Here's another description of how to do it from another post. http://forum.appliancepartspros...smission-oil-fill-2.html
Good luck with it. If you need oil, use the real Whirlpool oil or 50 wieght non detergent oil.
judbgrdmchn
#3 Posted : Sunday, November 7, 2010 5:33:43 AM(UTC)
judbgrdmchn
The tip about tapping the seal with a screwdriver & hammer was great, but I did dent the worn seal beyond use. Which Is unfortunate since the replacement seals are too small & its Sunday so I can't get a new one.
ThatGuy
#4 Posted : Sunday, November 7, 2010 5:39:35 AM(UTC)
ThatGuy
Groups: Expert
United States
What is the part number that you have?
I just checked and the part number I have is 285352 seal-oil aw.
It fits every WP gearcase that I have worked on in the last 20 years. (Its the larger of the two seals most of the time)
judbgrdmchn
#5 Posted : Sunday, November 7, 2010 7:47:59 AM(UTC)
judbgrdmchn
The gearcase is 389244, the seals say LP897 & 285352. I removed he defective seal & the new seals can fit inside of it, way too small. The old seal has several sets of writings in it. One set is illegible, 59, & 63387.
ThatGuy
#6 Posted : Sunday, November 7, 2010 4:31:43 PM(UTC)
ThatGuy
Groups: Expert
United States
The correct part for your gearcase is 285352 which crosses to this site's AP3043580.
It should fit. Can you measure your input shafts diameter with a caliper so we can see if its a standard one?
I just measured one of the ones I have sitting here and its a 1/2 inch shaft.
The outside diameter of the seal is 1 and 3/16 of an inch.
I hope that helps.
ThatGuy
#7 Posted : Thursday, November 11, 2010 7:36:18 AM(UTC)
ThatGuy
Groups: Expert
United States
So did you get the right seals for the gearcase?
judbgrdmchn
#8 Posted : Monday, November 15, 2010 5:52:21 PM(UTC)
judbgrdmchn
Yes, they had to special order the correct seal. The pack came with one like the original wrong seals and one that was the correct size.
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Maytag Washer MTW5740TQ0 leaking oil (?) from bottom (Washer Repair)
by scotpiper 4/8/2019 7:03:37 AM(UTC)
Whirlpool Leaking Oil and Clothes Still Damp (Washer Repair)
by jeffceo 1/29/2017 5:03:34 PM(UTC)
Washer leaking oil (Washer Repair)
by coldak 11/15/2015 1:27:11 PM(UTC)
Washer leaking oil onto floor (Washer Repair)
by gtg932 9/13/2014 11:02:12 PM(UTC)
Maytag Centennial Washer Leaking Oil (Washer Repair)
by hathawayrepair 2/16/2013 7:12:35 PM(UTC)
Washer Leaking Oil into Drum (Washer Repair)
by Jim Ortiz 2/14/2013 11:45:29 AM(UTC)
Washer does everything but spin, it is leaking oil (Washer Repair)
by regdor 7/26/2011 4:07:55 AM(UTC)
Leaking oil (Washer Repair)
by gordon_sorensen 6/10/2010 11:52:54 AM(UTC)
Washer leaking oil and water (Washer Repair)
by suefox51 12/5/2009 9:20:02 AM(UTC)
Maytag LAT9605AAE leaking oil and banging (Washer Repair)
by jaywilson 10/25/2009 4:20:08 PM(UTC)
washer leaking oil into washer (Washer Repair)
by swansea1950 9/18/2009 5:39:06 PM(UTC)
kenmore washer leaking oil (Washer Repair)
by scottwalsh 3/25/2009 1:19:36 PM(UTC)
Gearcase leaking oil (Washer Repair)
by leakycauldron 2/7/2009 9:13:02 AM(UTC)
by BILLY1129 7/9/2008 6:41:49 AM(UTC)
