crazyman
#1 Posted : Sunday, September 7, 2008 12:41:20 PM(UTC)
crazyman
this is a dual wave with microwave on top and regular oven below. Regular ovens temp is about a hundred degrees below digital display and digital display rules. A temporary fix is to set the temp about a hundred degrees above desired temp and use an oven thermometer. Where to start? Thanks Crazyman
#2 Posted : Monday, September 8, 2008 12:16:08 PM(UTC)
The model number you posted does not come up.
Verify and repost it, please.
Drags1998
#3 Posted : Monday, September 8, 2008 12:42:02 PM(UTC)
Drags1998
How old is this unit? 100 degrees is alot, check the resistance in the Sensor, 15 ohm at room temp.
samccollough
#4 Posted : Saturday, November 6, 2010 1:09:45 PM(UTC)
samccollough
Originally Posted by: MicrowaveDisplaycom Go to Quoted Post
That would be a defective oven thermostat (not to be confused with the microwave thermostat).
You can find it here as "Switch, thermostat".
The model number is generally referred to as one of these:
JKP78G*K1
JKP78G*K2
JKP78G*K3
JKP78G*K4
Happy to help.
Hello. I looked for "switch, thermostat" and came up empty. I saw a "thermostat" that has been discontinued.
Any advice? I have this unit with the same problem described above by crazyman, except my unit can fluctuate up or down significantly.
Thank you,
Sam
samccollough
#5 Posted : Saturday, November 6, 2010 1:15:35 PM(UTC)
samccollough
Thank you,
Sam
Update: I originally searched by model # and then looked at the parts list.
I just searched by part description using "switch, thermostat" and quite a few came up.
Can you possibly be more specific as to which part # is needed for this unit (JKP78G*K3)?
Thanks again,
Sam
#6 Posted : Monday, November 8, 2010 4:35:24 PM(UTC)
Sam,
Most likely the problem with your oven is a bad oven control board. Unfortunately this part has been discontinued and is no longer available.
Here are the breakdown diagrams and Replacement parts for General Electric JKP78G*K3 Electric range | AppliancePartsPros.com
samccollough
#7 Posted : Tuesday, November 9, 2010 2:53:06 PM(UTC)
samccollough
Thank you, Gene.
To clarify, please:
You are saying that the post, above, re the problem being the thermostat switch, is most likely incorrect?
FYI, I have already replaced the temp sensor, the lower heating element, and I sent the control board out to be serviced (it's been a while, I don't remember who serviced it). All to no avail.
Thanks again,
Sam
#8 Posted : Tuesday, November 9, 2010 3:40:57 PM(UTC)
Sam,
This thermostat switch is a safety device used for self clean and has nothing to do with the cooking temperature.
The oven sensor, the oven control board and the wiring harness between them - there is nothing else involved in the cooking temperature control.
