Ice machine takes a long time to make and dump ice, turned unit off and on, turned down temp
Originally Posted by: daveww  Ice machine takes a long time to make and dump ice, turned unit off and on, turned down temp Dave, How long does it take to make a batch of cubes ? On average, it takes 50 minutes from fill to refill under proper conditions, (freezer temp 0 dgrs and proper air flow in the freezer compartment). The cubes should be clear and solid, not hollow or appear to have layers. Also check for a proper door seal, and dispenser flapper seal, Have you checked and replaced your water system filter recently ? A slow fill, due to a clogged / dirty filter can delay the ice production as well. You may want to do these basic checks, and get back with us, so we have a better direction to take from here. :) :) :)
thanks I noticed that the temp is not very low and i can hear the freezer run a lot it dont think its the ice machine its just not cold enough Ive even turned it up all the way to 5
Originally Posted by: daveww  thanks I noticed that the temp is not very low and i can hear the freezer run a lot it dont think its the ice machine its just not cold enough Ive even turned it up all the way to 5 Dave, You should probably reset the control to mid range (3) and wait 24 hours, Check the air temperature on the middle shelf, You want to see somewhere between 3 and 5 degrees, that will correspond to a product temp of 0 degrees (usually). Always wait 24 hours between settings and adjust control 1 setting at a time,until you get to the reccomended temperature. Good Luck, :cool: :cool: :cool:
