4 Pages<1234>
#21 Posted : 17 years ago
Does the bar-drive (attached to the auger motor shaft) turn when the motor does?
The bar-drive
UserPostedImage
Karlasmommy
#22 Posted : 17 years ago
Karlasmommy
The bar-drive
UserPostedImage
Yes it moves. I can get ice through the door if I put ice in the drum. If I don't manually put ice in the drum it wont give me any ice.
#23 Posted : 17 years ago
What do you mean by drum? There is no such part. Can you describe this part?
Karlasmommy
#24 Posted : 17 years ago
Karlasmommy
Yes It Turns
#25 Posted : 17 years ago
Karlasmommy,
Please, answer the above question.
Karlasmommy
#26 Posted : 17 years ago
Karlasmommy
Karlasmommy,
I replaced the drive blade and the drum now it wont give me crushed ice but will dispense cubed. what is wrong with it now?
#27 Posted : 17 years ago
In that case the problem, most likely, is a bad solenoid.
Karlasmommy
#28 Posted : 17 years ago
Karlasmommy
You mean if it gives me cubed ice and not crushed the solenoid could be bad?
#29 Posted : 17 years ago
No, it was my mistake. If the solenoid is bad then it's going to be crushed ice only. You probably did something wrong while being working with the ice container.
P.S. You did not explain which part you called "drum" yet.
Karlasmommy
#30 Posted : 17 years ago
Karlasmommy
The drum is the round thing the ice goes in to go through the crusher blades.
4 Pages<1234>
