Does the bar-drive (attached to the auger motor shaft) turn when the motor does? The bar-drive Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does the bar-drive (attached to the auger motor shaft) turn when the motor does? The bar-drive Gene. Yes it moves. I can get ice through the door if I put ice in the drum. If I don't manually put ice in the drum it wont give me any ice.
What do you mean by drum? There is no such part. Can you describe this part?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What do you mean by drum? There is no such part. Can you describe this part?
Gene Karlasmommy, Please, answer the above question. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Karlasmommy,
Gene. I replaced the drive blade and the drum now it wont give me crushed ice but will dispense cubed. what is wrong with it now?
In that case the problem, most likely, is a bad solenoid.
You mean if it gives me cubed ice and not crushed the solenoid could be bad?
No, it was my mistake. If the solenoid is bad then it's going to be crushed ice only. You probably did something wrong while being working with the ice container.
Gene. P.S. You did not explain which part you called "drum" yet.
The drum is the round thing the ice goes in to go through the crusher blades.
