tkhighlander
#1 Posted : Sunday, August 10, 2008 3:34:25 PM(UTC)
tkhighlander
My refrigerator has an icemaker and a drinking water supply. I cannot get water to flow to either area. Could this be the water inlet valve?
kooler
#2 Posted : Sunday, August 10, 2008 9:18:07 PM(UTC)
kooler
It sure can be, there's usually a screen on the inlet of the water solenoid valve that can get plugged with sand, debris, you name it... Shutoff the water supply and disconnect the supply line at the valve to expose the screen and remove for cleaning.. Reassemble and test water fill to see if problem is resolved...
