Hi - my gas oven won't turn on. From reading the forums, it sounds like our problem is the igniter....but where is this and how do I replace it? I am rather afraid of gas, but can't really afford a tech to come in. Is there a diagram somewhere on the web also to follow? thank you so much...
In order to access the oven igniter you have to remove the oven floor and the flame spreader. The igniter is secured to the burner with the two screws. - The part number for the oven igniter is AP205873 Here are the break down diagrams for the Magic Chef range Model 31213WAVGene.
