bkeenom
#1 Posted : Tuesday, November 2, 2010 7:44:55 AM(UTC)
bkeenom
Both sides stopped cooling. searched advice on board and replaced start device with part number AP4079373 (67005560) Relay/capacitor. Now I can hear it click and it hums for a few seconds and stops. Compressor is getting warm but does not seem to be running. fans are running
#2 Posted : Wednesday, November 3, 2010 3:21:39 AM(UTC)
Feel the compressor to see if it is running, it should be vibrating. If it is starting up then shutting down on it's own, I would check to see if it is still getting power. If it is then odds are the compressor is toast. You could check it with a meter, see the link at the end of this post. If you measure a problem then you know that the compressor is toast but if it measures OK it does not eliminate the compressor as it may have internal mechanical problems.
If in fact the unit is still running but is a quiet compressor, I would remove the evaporator cover in the freezer so you can see the coils.
If there is no frost, then either the compressor is toast, you are out of freon or there is a plug in the sealed system.
If there is just frost in one area then you are probably low on freon.
Note: the above checks must be done after the unit has run for several hours, if you check it just after a defrost cycle then there will not be any frost.
In all the above you will need a pro and it will not be cheap.
Also there is no guarantee that they can fix it.
Often it makes more sense to put those dollars into the purchase of a new unit.
bkeenom
#3 Posted : Wednesday, November 3, 2010 4:58:32 AM(UTC)
bkeenom
The compressor is not running. I hear a click and a humming noise but the compressor isn't running. The compressor is getting warm. There is no ice buildup anywhere. I did not see the link to check the compressor.
#4 Posted : Wednesday, November 3, 2010 7:03:05 AM(UTC)
OOPS!
Sorry forgot to add the link.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
And here is another good site
http://www.applianceaid.com/frig.html
You will need a meter.
Kenmore side by side not cooling (Refrigerator & Freezer Repair)
by keller69 5/14/2012 9:46:20 AM(UTC)
by REAPHOTO 12/29/2010 6:39:14 AM(UTC)
Kenmore side by side not cooling or freezing (Refrigerator & Freezer Repair)
by williebones 10/17/2010 8:32:44 AM(UTC)
by booger32 3/19/2010 7:27:17 PM(UTC)
