airylee
#1 Posted : Tuesday, November 2, 2010 9:41:12 AM(UTC)
airylee
Model ED25DQXBW00. Following move (and with the water supply to the ice maker disconnected) re started the fridge, Worked fine and ran for approx. 5 hours. Unit was working fine and cooling down normally. After approx. 5 hours run time, GFI into which unit was plugged tripped out. Reset GFI and fridge restarted. Ran approx 4 - 5 min. then it again tripped out GFI. I Re reset GFI. Unit will not start/run. I checked it again after sitting over night and unit will not start up. Could it have shut down due to an overheat condition? Or, is there some type of interlock system with the ice maker that shuts down the unit if the ice maker is not operating (I experienced this with same/similar Whirlpool fridges)?
magician59
#2 Posted : Tuesday, November 2, 2010 1:10:26 PM(UTC)
magician59
It's probably a weak GFCI outlet. Refrigerators are not supposed to be used on a GFI-protected circuit. The easiest thing to do is replace the outlet with a new GFCI; but you really need the refrigerator to be on its own 20-Amp circuit.
Whirlpool WRF535SWHZ07 Won't Program Control Board (Refrigerator & Freezer Repair)
by Guest 7/5/2024 1:43:28 AM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool fridge WRF560SFYM02 (Refrigerator & Freezer Repair)
by Guest 6/15/2024 5:02:08 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool wtw500dw1 won't fill (Washer Repair)
by Guest 6/9/2024 4:14:40 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool LA5700XTN0 won't agitate (Washer Repair)
by Kyou 6/2/2024 5:13:20 PM(UTC)
Whirlpool Flame Cuts off After 5-10 seconds (Dryer Repair)
by Guest 6/1/2024 8:00:29 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
