hitman401
#1 Posted : Monday, November 1, 2010 1:16:19 PM(UTC)
hitman401
this is a wall oven .when i turn it on it does not heat up at all upper or lower elements do not get hot.this happend all at once...... what could this be?or what part do i need?
#2 Posted : Monday, November 1, 2010 1:39:20 PM(UTC)
Replacement parts for FRIGIDAIRE FES367ABG Frigidaire/electric Range | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318045067.pdf
Something is wrong the model number comes up as a slide in range not just an oven.
First thing you want to do is check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is good then it is probably the control board though some units have a thermal cutout that can cause problems.
Guest (4)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Maytag Oven Will Not Heat Up (Oven Repair (including Ranges and Cooktops))
by debost 1/16/2013 9:46:49 AM(UTC)
Whirlpool Gas Oven will not heat up to desired temperature. (Oven Repair (including Ranges and Cooktops))
by captjob 7/29/2012 5:45:19 PM(UTC)
Double Oven will not heat up past "LOW" (Oven Repair (including Ranges and Cooktops))
by jnichols_1967 2/6/2012 7:52:56 AM(UTC)
Whirlpool Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by stgdobber 5/3/2011 11:19:32 AM(UTC)
Fridgedaire gas range-oven will not heat up (Oven Repair (including Ranges and Cooktops))
by ccjden 3/17/2011 9:52:26 AM(UTC)
by casey114 12/16/2010 11:57:59 AM(UTC)
KitchenAid oven will not heat up... replace thermostat? (Oven Repair (including Ranges and Cooktops))
by Matt M 12/7/2010 11:42:49 AM(UTC)
Oven will not heat up, gas won't flow (Oven Repair (including Ranges and Cooktops))
by spystyle 11/23/2010 3:57:13 PM(UTC)
Dacor Epicure oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jeab 8/10/2010 11:46:30 AM(UTC)
by ar.muncy 3/17/2010 8:47:54 AM(UTC)
Gas Jenn-Air oven will not heat up? (Oven Repair (including Ranges and Cooktops))
by Tony3 12/17/2009 8:04:58 AM(UTC)
by tmurch 10/15/2009 10:56:39 AM(UTC)
