plink49
#1 Posted : Thursday, August 7, 2008 10:40:11 AM(UTC)
plink49
Dishwasher runs and cleans just fine, but during the drain cycle water leaks quite profusely from the air gap. Since the air gap is such a cheap part I replaced it but to no avail. Also, there is no blockage in the drain hose or the sink drain. Help!
abadfish66
#2 Posted : Thursday, August 7, 2008 10:44:25 AM(UTC)
abadfish66
There is only one reason that it will leak from there, somewhere between the the airgap and your garbage disposer, there is a clog or kinked line. Take off the hose from the disposer and inspect it, also inspect the opening at the disposer where the drain line connects to.
plink49
#3 Posted : Thursday, August 7, 2008 11:54:37 AM(UTC)
plink49
Thanks for the input! I couldn't find any kinks or blockages, but I replaced the hose with a much shorter one with no loop in it and provided a more direct route to the "tee" connection in the sink drain and all is well!:)
