dbraun
#1 Posted : Monday, April 26, 2010 2:13:34 PM(UTC)
dbraun
Some of the cycle selection buttons don't work at all (e.g., Econowash). Other buttons work only after pressing several times. What repair part do I need?
hil357
#2 Posted : Sunday, October 31, 2010 6:52:20 AM(UTC)
hil357
Did you ever find an answer? Im having the same problem. Thanks
#3 Posted : Monday, November 1, 2010 1:20:39 PM(UTC)
You do not seem to be getting an answer, so I will give it a shot.
The original poster may still jump in but in the mean time some is better than none.
I a cannot find a control panel (keypad) schematic so cannot help with you testing it for continuity.
You may want to try the following. On most units a number of keys will use a common track on the ribbon cable. If this track cracks or makes a poor connection you loose a number of keys usually 3 or 4.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Frigidaire dishwasher fills and drains does not wash (Dishwasher Repair)
by Guest 9/19/2023 12:06:34 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
I20 error on brand new Frigidaire dishwasher (Dishwasher Repair)
by Guest 2/8/2023 6:50:55 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire dishwasher Model # LFID2422RF4B (Dishwasher Repair)
by lharwerth 11/22/2021 7:15:45 AM(UTC)
Frigidaire dishwasher ffbd2406nb3a no cleaning the dishes (Dishwasher Repair)
by Yolando 4/6/2021 5:50:57 PM(UTC)
Frigidaire Dishwasher ffbd2411ns1a Noise (Dishwasher Repair)
by bdwashburn 8/3/2020 11:11:43 AM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Frigidaire Dishwasher FDB1250REC0 no lights (Dishwasher Repair)
by Idesignedit 9/2/2019 9:37:32 AM(UTC)
Frigidaire Dishwasher FFBD2406NB0A (Dishwasher Repair)
by Brian P Mark 4/18/2019 4:54:21 AM(UTC)
Frigidaire Dishwasher LGID2475QF5A i20 error code (Dishwasher Repair)
by 210matt 11/4/2018 3:32:21 PM(UTC)
Frigidaire Dishwasher Soap Still Remains (Dishwasher Repair)
by Kryptonite 4/5/2018 12:21:21 PM(UTC)
*plz Help* Frigidaire Dishwasher Top Sprayer Will Not Work *plz Help* (Dishwasher Repair)
by Timma9705 2/21/2018 8:14:48 AM(UTC)
