2 Pages12>
ChipET
#1 Posted : Thursday, October 28, 2010 11:06:03 AM(UTC)
ChipET
Went to use dishwasher again after using just an hour or so earlier and nothing is working. I checked the power outlet in the wall and there is power there. After reading a few post on here replaced the latch switches with the new switches and wiring harness, still nothing. IM not too sure where to go from here, please help.
The reason I chose to replace the door switch kit first was one of the connections was burned out, see attached, only thing I saw that didnt look right.
ChipET attached the following image(s):
magician59
#2 Posted : Thursday, October 28, 2010 11:27:41 AM(UTC)
magician59
Did you check for power at the electrical connection to the dishwasher?
ChipET
#3 Posted : Thursday, October 28, 2010 11:29:37 AM(UTC)
ChipET
Out of the wall, yes there is power, not sure how to check power at the actual unit, mechanical minded guy here, not really to versed on electricity!
magician59
#4 Posted : Thursday, October 28, 2010 11:45:38 AM(UTC)
magician59
That was my next question. You can get hurt badly by touching the wrong thing. The area to check is located inside a small metal box, right behind the toe panel. Its cover is usually held in place with a 1/4'' hex-drive screw. If you're not comfortable doing live-voltage checks, the best gift you can give your family is to call in an appliance pro to diagnose for you.
ChipET
#5 Posted : Thursday, October 28, 2010 11:52:30 AM(UTC)
ChipET
Well I will see what I can do about that, either call a friend that knows what to touch and what not to touch, but the rates at which appliance repair callout will cost me is too mcuh for me to bitwe down on. If i am getting power to the unit what would you think would be the next thing to look at ?
magician59
#6 Posted : Thursday, October 28, 2010 12:54:01 PM(UTC)
magician59
Check the float inside the tub to make sure there isn't a fork, spoon, gunk, etc. keeping it stuck in the up position.The next thing to check is the float switch, itself. Then see whether the door latch is activating the switches.
If you're getting power all the way to (and through) the door switches, I would suspect either a touch pad or a control board.
BTW: I didn't intend to insult you with my previous post. I just prefer to remind folks that safety is far more important than the conveniences of modern appliances.
ChipET
#7 Posted : Thursday, October 28, 2010 1:17:18 PM(UTC)
ChipET
Thank you for the suggestions, no insult taken, I just don't want to spend $100 plus for someone to come and replace a $10 part, you know what I am saying. I am also appreciative of the warning on the electrical side of things, that is why i don't like messing with it because I am un-educated in that side of things. Trust me i want to be safe too. Looking through here some more could it possibly be the thermal fuse, that and the door latch components seem to be a regular occurrence of problems for this model.
#8 Posted : Thursday, October 28, 2010 3:07:24 PM(UTC)
Here is the parts breakdown
Replacement parts for DU943PWKTO models | AppliancePartsPros.com
Check out the thermal fuse Item 4 in Section 1.
It should be 0 ohms.
Unplug/remove power from the unit and check the fuse with a meter.
If it is blown be sure to use the new harness that comes with it.
ChipET
#9 Posted : Thursday, November 4, 2010 10:03:35 AM(UTC)
ChipET
Problem fixed....ended upi being the Thermal fuse was blown, thanks guys for the tips and suggestions to helping me repair my dishwasher
ChipET
#10 Posted : Monday, December 13, 2010 6:03:21 AM(UTC)
ChipET
OK I have blown the fuse again, dishwasher dead in the water....
What could cause the fuse to keep blowing ?
Whirlpool top load washer Model # WTW58ESVW quit working (Washer Repair)
by chuck gibson 3/12/2021 4:37:30 PM(UTC)
Summit Freezer quit working (Refrigerator & Freezer Repair)
by TheBishop 7/30/2018 7:18:00 PM(UTC)
Dryer quit working after thorough cleaning (Dryer Repair)
by boonjh 2/13/2016 6:33:33 PM(UTC)
Ice maker suddenly quit working (Refrigerator & Freezer Repair)
by pkner00 8/18/2015 12:31:03 PM(UTC)
half of keypad quit working (Oven Repair (including Ranges and Cooktops))
by Richard Heller 12/18/2014 8:39:13 PM(UTC)
Big burner quit working on Whirlpool 30" freestanding range (Oven Repair (including Ranges and Cooktops))
by DeltaFox 11/22/2014 10:16:36 AM(UTC)
Freezer then Fridge quit working in last 24 hours (Refrigerator & Freezer Repair)
by sstargell 1/17/2014 6:02:18 AM(UTC)
Magic Chef RV Oven quit working, top burners are fine (Oven Repair (including Ranges and Cooktops))
by grecoiii 11/17/2013 2:40:50 PM(UTC)
Fridge/Freezer Quit Working (Refrigerator & Freezer Repair)
by garyb79ag 9/6/2013 12:25:32 PM(UTC)
Maytag refrigerator and freezer quit working after thawing with heat gun (Refrigerator & Freezer Repair)
by Allrevedup 7/30/2013 5:08:47 PM(UTC)
Washer (combo) quit working after removing dryer door (Washer Repair)
by RandyJ 3/21/2013 9:11:43 AM(UTC)
Jen Air oven quit working (Oven Repair (including Ranges and Cooktops))
by TerryInLeesburg 3/11/2013 8:39:18 AM(UTC)
GE Profile Range lower oven quit working (Oven Repair (including Ranges and Cooktops))
by mdenbow 10/18/2012 11:02:54 AM(UTC)
Kitchenaid Double oven quit working after running a cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sharon1 8/10/2012 11:52:21 AM(UTC)
Ice Maker Quit Working (Refrigerator & Freezer Repair)
by dave2425 7/23/2012 8:45:20 AM(UTC)
2 Pages12>
