The thermostat calls for heat, the furnace lights but when the fan switch should start the blower, the furnace hi-temps (shuts the gas valve off) then the blower starts after about 2 1/2 minutes. Soon the gas valve relights the burners and all runs well...What should I be looking for?
Thank you!
I replaced the Camstat with a fan switch w/ safety...works fine now!:eek:
