khart26
#1 Posted : Monday, August 4, 2008 11:13:07 AM(UTC)
khart26
Hopefully someone can help me. I had my sump pump stop working witch backed water up all over from my washing machine .. the machine overflowed. Since then my washer wont agitate. I turn it on and it fills but it like gets stuck and if I dont manually move the timer it will keep filling and overflow. It won't agitate either, it goes from filling to draining, it does spin and the timer does move from spinning to turning off by itself. It gets stuck only when it is filling up in the beginning or rinsing. Any ideas? Thank you
#2 Posted : Tuesday, August 5, 2008 10:58:47 AM(UTC)
Open the control panel and check if the pressure hose (clear plastic hose) is properly attached to the water pressure switch (#5 on the break down diagram) and it's not broken.
If there is nothing wrong then, most likely the problem is a bad water pressure switch.
- The part number for the water pressure switch is AP2105893
