AmandaWolken
#1 Posted : Monday, October 25, 2010 6:58:35 PM(UTC)
AmandaWolken
We purchased a Frigidaire Electrolux Gallery Series Model number glef378cqb series vf33136697. The stove works great, the convection fan and oven light turn on, but the burners don't turn on in the oven. I read on another post that he might need an EOC Controller. Is that what mine would be too?
magician59
#2 Posted : Monday, October 25, 2010 7:20:15 PM(UTC)
magician59
A good place to start is to see if you have 240VAC at the outlet. Then check to make sure your electrical connections at the range are secure.
#3 Posted : Tuesday, October 26, 2010 5:13:23 AM(UTC)
Replacement parts for FRIGIDAIRE GLEF378CQB Frigidaire/electric Range | AppliancePartsPros.com
And the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255318.pdf
If both things magician59 chesk out OK then odds are that the control board (Item 20 in Section 1) is toast
#4 Posted : Tuesday, October 26, 2010 5:19:07 AM(UTC)
If both things magician59 check out OK then odds are that the control board (Item 20 in Section 1) is toast.
There is always a possibility that both elements are burned out but this would be a long shot to say the least.
