mamadoog
#1 Posted : Monday, August 4, 2008 11:04:01 AM(UTC)
mamadoog
When dryer comes on it has loud squeaking noise, then after awhile it quits. I sprayed idler arm with LPS 1, it quite for a while but came back. Help please.
#2 Posted : Tuesday, August 5, 2008 10:50:47 AM(UTC)
Remove the front panel and the front bulkhead assembly (#5 on the break down diagram). Check both glides (front supports for the drum, # 11 on the break down diagram).
Remove the drum and check the rear drum support rollers (#16 on the break down diagram).
Electric dryer squeaking, squealing, and screaming. (Dryer Repair)
by Kurtzero 1/11/2018 4:26:56 PM(UTC)
Frigidaire Dryer squeaking (Dryer Repair)
by Gene.Dixon 9/22/2014 1:06:50 PM(UTC)
GE Harmony Dryer squeaking (Dryer Repair)
by kurtd 5/16/2014 4:34:32 AM(UTC)
GE gas Dryer Squeaking and now grinding (Dryer Repair)
by firefly 8/29/2012 8:31:09 PM(UTC)
Frigidaire Dryer Squeaking (Dryer Repair)
by rgrandmaison5@gmail.com 3/18/2012 6:19:24 PM(UTC)
by rherm52 3/11/2012 6:40:15 AM(UTC)
Dryer squeaking when spinning (Dryer Repair)
by Geno Altiery 11/25/2011 5:16:35 PM(UTC)
Maytag Dryer Squeaking and Timer Problem (Dryer Repair)
by Bob M 8/6/2011 11:08:23 AM(UTC)
Dryer Squeaking loudly (Dryer Repair)
by tculler 3/16/2011 4:51:02 PM(UTC)
Maytag Dryer Squeaking (Dryer Repair)
by mikecno 2/22/2011 7:31:17 AM(UTC)
by toolguy47 9/21/2010 5:58:40 PM(UTC)
by DOAinNY 7/6/2010 5:01:31 PM(UTC)
GE Electric Dryer Squeaking then not rotating (Dryer Repair)
by kenro 11/28/2009 6:27:03 AM(UTC)
Amana dryer squeaking (Dryer Repair)
by Barry Briggs 11/5/2009 9:30:37 AM(UTC)
Duet Dryer Squeaking (Dryer Repair)
by cdelonis 5/24/2009 10:19:11 AM(UTC)
