andrewlee
#1 Posted : Friday, August 1, 2008 8:30:10 PM(UTC)
andrewlee
My dishwasher has an odor. I replaced the garbage disposal, I wonder if i did something wrong. The odor is a mildew type odor
Andrew
#2 Posted : Saturday, August 2, 2008 12:57:21 AM(UTC)
Did you elevate the dishwasher drain hose to prevent garbage from draining into the dishwasher??
DesertDeuces
#3 Posted : Sunday, August 3, 2008 7:37:34 PM(UTC)
DesertDeuces
When you replaced the garbage disposal, did you knock out the plug inside the garbage disposal where the rubber hose connects to the air gap? If not, your water will not drain properly.
Replace the air gap. Always a good idea when changing garbage disposals. They're cheap enough and they often get clogged with debris from the garbage disposal. Also, change the hose from the garbage disposal to the air gap.
This should provide the needed aeration for the water to flow properly, thus preventing mildew.
