breichman
#1 Posted : Tuesday, October 19, 2010 7:54:19 AM(UTC)
breichman
The inner glass panel on my oven cracked. When I took the door apart there was three glass panels, one of which was the inner most cracked panel. I looked for the part number of this glass and I cannot find it in the parts catalog. Every catalog that I looked at shows the door only having two glass panels. The panel that I need to replace was mounted in the inner door panel. Can you tell me if the panel when ordered comes with that glass mounted in it?
#2 Posted : Tuesday, October 19, 2010 5:27:42 PM(UTC)
Here is your parts breakdown
Replacement parts for WHIRLPOOL RBS305PDQ6 | AppliancePartsPros.com
I may be out to lunch but here is my take on the glass panels, see Section 2
15 is the outer glass
7 is the middle glass
3 is the inner glass
breichman
#3 Posted : Wednesday, October 20, 2010 5:22:54 AM(UTC)
breichman
Thank you for the response, I figured out that the glass panel that I need is in fact #3 in the diagram. Let me explain what caused the problem. Number 15 is the outside panel of the oven door which is white in my case. Number 7 is a thinner glass panel that is inside of the door and in my door I actually had two of those panels. They were mounted next to each other so when I took the door apart I had three glass panels not counting the outside of the door. I am not sure why I had two of the panels marked #7 but I did have them in the door.
#4 Posted : Wednesday, October 20, 2010 7:24:56 AM(UTC)
It could be that they had too much heat getting to the outer door glass so added another center glass and then did not bother updating their parts lists.
I do agree with you that #3 should do the job.
