The inner glass panel on my oven cracked. When I took the door apart there was three glass panels, one of which was the inner most cracked panel. I looked for the part number of this glass and I cannot find it in the parts catalog. Every catalog that I looked at shows the door only having two glass panels. The panel that I need to replace was mounted in the inner door panel. Can you tell me if the panel when ordered comes with that glass mounted in it?
THIS FORUM IS DEAD!!!!!!! |
Thank you for the response, I figured out that the glass panel that I need is in fact #3 in the diagram. Let me explain what caused the problem. Number 15 is the outside panel of the oven door which is white in my case. Number 7 is a thinner glass panel that is inside of the door and in my door I actually had two of those panels. They were mounted next to each other so when I took the door apart I had three glass panels not counting the outside of the door. I am not sure why I had two of the panels marked #7 but I did have them in the door.
It could be that they had too much heat getting to the outer door glass so added another center glass and then did not bother updating their parts lists.
I do agree with you that #3 should do the job. |
