SRB
#1 Posted : Thursday, July 31, 2008 6:40:12 PM(UTC)
SRB
My Fisher & Paykel washer model #GWL10US purchased in 2001 is not working. It will not fill or spin. It tries for a couple of seconds and repeats several times, then beeps every second with the lighting code as follows: _ _ G _ G _ Y R
I made sure the inlet screens on both cold and hot were clean. I also confirmed that the discharge hose was clear and inspected the diverter valve for debris. Please help, the clothes are piling up.:confused:
dadoes
#2 Posted : Sunday, November 2, 2008 9:34:24 AM(UTC)
dadoes
Fault code 43 refers to the out-of-balance switch. It's either stuck on, corroded/gone bad, or (less likely) the motor control board is bad.
Front load washer will not work in spin cycle (Washer Repair)
by jldmadlove 3/21/2012 10:15:28 AM(UTC)
frontload washer will not work on any setting (Washer Repair)
by candygaylor 4/30/2011 12:22:30 PM(UTC)
Washer Will Not Work (Washer Repair)
by anthonyd 1/27/2011 7:01:05 AM(UTC)
dishwasher will not work (Dishwasher Repair)
by rayjhay 6/24/2008 6:15:38 PM(UTC)
