Kip4500
#1 Posted : Monday, October 18, 2010 9:07:54 AM(UTC)
Kip4500
The dryer is leaving small brown marks on mostly white cloths. I searched the internet and this seems to be a known issue with the front/back felt seals.
I was hoping someone could verify before I ordered the parts and if there is anything else I need to check.
Thanks in advance for any help you can give.
Kip
kayakcrzy
#2 Posted : Monday, October 18, 2010 2:51:56 PM(UTC)
kayakcrzy
Kip
Yes, i would replace the front and the rear felt seals. They will come with some high temp adhesive. When you put them on, put the dryer back together, and let it sit for an hour so the seals will be fully dry. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Kip4500
#3 Posted : Monday, October 18, 2010 3:27:24 PM(UTC)
Kip4500
Thanks for the info. I will order the seals and give it at try.
badbackguy
#4 Posted : Tuesday, October 19, 2010 10:53:17 AM(UTC)
badbackguy
Here are a couple videos that will help with the installation
Dryer rear seal replacement video
Dryer Front Seal Replacement Video
