green
#1 Posted : Thursday, October 29, 2009 1:42:40 PM(UTC)
green
I had to replace the tube connector (rubber) on my KUDR24SE KitchenAid Dishwasher. I was told that part is no longer available and that I had to purchase the Middle Spray Arm & Supply Tube Kit. I received it with NO directions. Some of the pieces are a little different and am having problems putting it together. Nothing is labeled, do I use the old screw from the bottom to attach it? Do I use the old part that has a thin nozzle?????? Help would be greatly appreciated. Thanks
#2 Posted : Thursday, October 29, 2009 5:40:26 PM(UTC)
This kit contains of 5 parts which should be installed. There is only one screw (#2 on the diagram) and you have to use the old one. The diagram should help you to better understand the parts sequence.
green
#3 Posted : Friday, October 30, 2009 5:32:18 AM(UTC)
green
Hi Gene!
Thank you soooo much for responding quickly. I placed everything in and now my problem is that THE ARM IS NOT SPINNING FREELY. It seems to be to close. I used the old #2(on top), #17, #5 parts and the new #2 for the bottom. I placed this in the same spot on the top wire rack. There doesn't seem to be another spot to place it. The spacing for the wire rack is ~2 inches and the rest are ~ 1 1/2?????? Thanks
#4 Posted : Friday, October 30, 2009 1:21:59 PM(UTC)
You might want to double check everything. There is nothing complicated.
Flat
#5 Posted : Monday, October 18, 2010 9:43:51 AM(UTC)
Flat
I am in a similar situation and need to know if I need to buy the whole kit or can I just buy the the tube itself as my current "soft" tube is worn out and needs replacement.
#6 Posted : Monday, October 18, 2010 1:56:48 PM(UTC)
The complete model number of the dishwasher may help other to help you.
Flat
#7 Posted : Tuesday, October 19, 2010 4:25:31 AM(UTC)
Flat
Hi Gene,
It is Model# KUDC25CHBL1
#8 Posted : Saturday, October 23, 2010 4:41:48 PM(UTC)
Hi Gene,
Flat,
Your model is different and you don't have to buy the hole kit. Buy whatever is broken.
If you do need just the tube, then the tube Part number: AP3045018
