lwb
#1 Posted : Wednesday, July 30, 2008 4:47:12 AM(UTC)
lwb
When I pulled off the float and washer assembly, the washer and all came off the end, and fell back in the hole. Can I get this out, or can I just take the float to a hardware store and get a new washer assembly?
#2 Posted : Wednesday, July 30, 2008 7:17:51 PM(UTC)
Remove the bottom panel.
Here are the break down diagrams for the Whirlpool dishwasher Model DU920PWKB0
lwb
#3 Posted : Wednesday, July 30, 2008 7:22:42 PM(UTC)
lwb
I did order the part today from website. When it comes, do I just insert it in the hole, or do I need to push it in tight?
#4 Posted : Wednesday, July 30, 2008 7:35:03 PM(UTC)
Looking at the diagram I can see the nut (#33) which goes from under the dishwasher.
lwb
#5 Posted : Friday, August 1, 2008 6:27:12 AM(UTC)
lwb
Okay, I see that. Will it screw or pop in. I don't see any threads on the end of the float assembly.
Guest (5)
