phonore
#1 Posted : Tuesday, July 29, 2008 5:04:35 PM(UTC)
phonore
I need to replace the light switch in my Frigidaire frig Model # frs26zthb1. Looks simple: there are two screws holding a panel which contains the switch, bulb and cold control. Can I just drop that panel? Then what's the next step?
#2 Posted : Wednesday, July 30, 2008 4:52:30 PM(UTC)
Yes, you can remove the control panel (do not forget to unplug the refrigerator) and easy replace the light switch (#114 on the break down diagram).
- The part number for the light switch is AP2143984
Here are the break down diagrams for the Frigidaire refrigerator Model FRS26ZTHB1
phonore
#3 Posted : Wednesday, July 30, 2008 4:58:25 PM(UTC)
phonore
Thanks, Gene. I was able to replace the switch without taking off the panel. I noticed the replacement switch had a couple of "barbs". I pushed a thin knife blade in behind the outer rim of the switch, depressed the barb and got one side free and then just wiggled it out.
#4 Posted : Wednesday, July 30, 2008 5:03:52 PM(UTC)
I showed the easiest way but you choose more professional one. Good job.
