jimgpe
#1 Posted : Friday, October 15, 2010 10:44:50 AM(UTC)
jimgpe
I am replacing the high limit p/n 341195 with a 341222. The original limit was a SPST. The replacement is a SPDT. Do I use the normally closed or normally open contacts? I can't test the original as it blew up into its constituent parts when it failed!
Thanks!
Jim.
magician59
#2 Posted : Friday, October 15, 2010 10:58:10 AM(UTC)
magician59
Here's the correct replacement part.Part number: AP3094087
jimgpe
#3 Posted : Friday, October 15, 2010 11:06:29 AM(UTC)
jimgpe
That's the part I received. So do I use the NO or NC contacts?
magician59
#4 Posted : Friday, October 15, 2010 12:53:27 PM(UTC)
magician59
I must be missing something, here (This thermostat only has two contacts.); but if your thermostat gives you a choice, use the normally closed one.
