I am replacing the high limit p/n 341195 with a 341222. The original limit was a SPST. The replacement is a SPDT. Do I use the normally closed or normally open contacts? I can't test the original as it blew up into its constituent parts when it failed!
Thanks!
Jim.
Originally Posted by: magician59 That's the part I received. So do I use the NO or NC contacts?
I must be missing something, here (This thermostat only has two contacts.); but if your thermostat gives you a choice, use the normally closed one.
