scrowley111
#1 Posted : Tuesday, July 29, 2008 1:36:34 PM(UTC)
scrowley111
I have a kenmore side by side fridge and freezer with ice maker and water. It only gets slightly cold even while on for hours. I can hear the fan in the bottom back running constantly. Definatley not cold enough to keep the food good. I don't know a lot about fridges but i am very handy. Just need to be pointed in the right direction. any help would be greatly apprectiated. thanks scott
#2 Posted : Wednesday, July 30, 2008 8:20:39 AM(UTC)
Remove the back panel in the freezer and check the coils. If only a small area of frost, you probably have a bad compressor, or a bad freon leak. Both over $400 to fix, probably new fridg. time.
scrowley111
#3 Posted : Wednesday, July 30, 2008 11:58:45 AM(UTC)
scrowley111
thanks for the info. I will check that. I hope thats not the case but i will check. thanks.
