OrikKvisa
#1 Posted : Monday, October 11, 2010 11:43:49 AM(UTC)
OrikKvisa
My dryer turns on and has very low heat, even when the setting is on the highest heat. Any suggestions what is wrong with it? :)
Thanks!
o
Joe / APP Team
#2 Posted : Monday, October 11, 2010 12:54:41 PM(UTC)
Joe / APP Team
Thanks!
o
Orik,
Have you checked your exhaust venting and lint filter for excessive lint build up ?
That could give you the impression of a low temperature, be cause it is overheating and turning the burner off.
There are several other possibilities, bad temperature switch, bad bias heater, being a gas unit you could also have a weak coil, cracked igniter, etc.
Check the exhaust vent an hood for build up first, then we can go from there.
:cool: :cool: :cool:
