rwcrazy
#1 Posted : Monday, October 4, 2010 5:28:08 PM(UTC)
rwcrazy
this washer just stopped working, i checked for power and there is no power at the timer control? is this possible the problem?
#2 Posted : Tuesday, October 5, 2010 3:50:38 PM(UTC)
It is possible the lid switch stops all power, I would check it first. If ok, I would pull the cover off the timer and look for burnt contacts. If so, you need a new timer. If one or two contacts are not burnt, but melted and fused open, you have a shorted motor! Lid switch AP3094500, timer, AP3607885
rwcrazy
#3 Posted : Tuesday, October 5, 2010 4:25:02 PM(UTC)
rwcrazy
I pulled the timer off and nothing is burned
#4 Posted : Wednesday, October 6, 2010 5:54:01 AM(UTC)
If nothing is working, I would check the wall outlet.
Guest (4)
WHIRLPOOL Washer dead (Washer Repair)
by rwcrazy 10/4/2010 1:32:48 PM(UTC)
