quicksilver147
#1 Posted : 14 years ago
quicksilver147
Can anyone help ?
I have a DU9000XR-5 that came with our home (House built in 1988).
The unit quit last night (nothing happens when you try to start it), and I'm not sure how old the unit is or where to start with it ??
Any help would be much appreciated.
Joe / APP Team
#2 Posted : 14 years ago
Joe / APP Team
Originally Posted by: quicksilver147 Go to Quoted Post
Can anyone help ?
Quick,
Are you sure the breaker didn't trip open ?
I would start at the junction box on the frame, make sure the connection is
not loose, then check the door latch switch and latch assembly for operation.
There's not a lot of information on a Dishwasher of this age, but start there
and hopefully, you'll be up and running soon.
Good Luck,
quicksilver147
#3 Posted : 14 years ago
quicksilver147
I know the unit has power (pannel indicators glow), and I dont think the door latch is the issue.
I dont see a mfg date on the unit, is there a way to tell ?
Joe / APP Team
#4 Posted : 14 years ago
Joe / APP Team
I dont see a Manufacturer date on the unit, is there a way to tell ?
The manufacturers date code is (usually)in the serial number.
First two numbers is the week of manufacture.
Last letter is the year of manufacture.
My date code information only goes back to 1990.
If you have power to the control panel, then I doubt the door switch is the problem.
Now we're into a loose or broken wire(not likely), bad control switch or timer ?
Good Luck,
:cool: :cool: :cool:
quicksilver147
#5 Posted : 14 years ago
quicksilver147
My S/N is F91517188
So does this mean my year of mfg would be 1988 ?
If so.......im gonna have troulble getting some parts for this thing I bet.
For Example--When I checked on the timer it was discontinued
Joe / APP Team
#6 Posted : 14 years ago
Joe / APP Team
My S/N is F91517188
So does this mean my year of Manufacturer would be 1988 ?
I actually figure it's older, closer to 86' for a production date.
Yes , you are probably going to have difficulty getting parts.
