girlw/o-a-clue
#1 Posted : 14 years ago
girlw/o-a-clue
My fridge stopped working; I replaced the timer, then the thermostat, now it works, but I have a frost built-up on the lower back panel in the freezer. I have no clue what to do next. Any help for this gal.
Joe / APP Team
#2 Posted : 14 years ago
Joe / APP Team
Girl W/O,
Check for a clogged, frozen defrost drain pan and tube.
Check and make sure, the freezer door seal and mullion strip are sealing proper ,
Check the refrigerator ceiling for ice, frost, or droplets.
I'm guessing, you determined the defrost heater was OK ?
Start there, and let us know what you found.
Good Luck,
girlw/o-a-clue
#3 Posted : 14 years ago
girlw/o-a-clue
Joe, I will check the heater; I'm not sure where it is, but I have a book, so that should make it easier. Sorry about being in the oven--forum. I'm new as you can tell, but trying to learn.
Joe / APP Team
#4 Posted : 14 years ago
Joe / APP Team
Not a Problem...
Your defrost heater is attached to the evaporator, runs across the bottom and about 1/2 way up both sides.
Be carefull,
The fins on the evaporator are SHARP.
:cool: :cool: :cool:
LG Freezer Frost Buildup (Refrigerator & Freezer Repair)
by joe475 4 years ago
upright freezer frosting/icing after gasket replacement (Refrigerator & Freezer Repair)
by woakley 5 years ago
Kenmore Bottom Freezer Frost Buildup (Refrigerator & Freezer Repair)
by EdBurkett 7 years ago
Samsung Freezer frost developing (Refrigerator & Freezer Repair)
by tigers12 8 years ago
Freezer frosting and too warm (Refrigerator & Freezer Repair)
by tracyhall63 10 years ago
Freezer frosting/frige warming (Refrigerator & Freezer Repair)
by Sonicgt02 10 years ago
Freezer frosting over, fridge not cold (Refrigerator & Freezer Repair)
by spowel007 11 years ago
fridge warm andback of freezer frosts over (Refrigerator & Freezer Repair)
by birdmama 12 years ago
freezer frosting up (Refrigerator & Freezer Repair)
by hammerman 12 years ago
GE GS Fridge/Freezer frosted over (Refrigerator & Freezer Repair)
by aero3685 12 years ago
Freezer frost,defrost cycling causing snow (Refrigerator & Freezer Repair)
by DAWOLFESR 13 years ago
Freezer frost - refrigerator not cooling (Refrigerator & Freezer Repair)
by NOLGAC 13 years ago
Top of freezer frosting over (Refrigerator & Freezer Repair)
by fst-tlk 13 years ago
Freezer frosting but still cold (Refrigerator & Freezer Repair)
by Billyjo 14 years ago
freezer frost up (Refrigerator & Freezer Repair)
by RileyBailey 14 years ago
