This unit works perfectly for aprox. 1-2 months then it will freeze up. I have checked the defrost coil , it all right. Could the problem be in the control board.This problem seem to start when I removed the Ice crusher and despenser system.The Ice maker works OK Untill the unit freezes up.
it may be board ,check wires connected to heater ,sometimes they will burn
Thanks so much for the help. I will check the connections on the element.let you know what I find.Thanks again.
