Dave Turman
#1 Posted : Friday, July 25, 2008 6:18:10 AM(UTC)
Dave Turman
This unit works perfectly for aprox. 1-2 months then it will freeze up. I have checked the defrost coil , it all right. Could the problem be in the control board.This problem seem to start when I removed the Ice crusher and despenser system.The Ice maker works OK Untill the unit freezes up.
misterfixall
#2 Posted : Friday, July 25, 2008 11:25:41 AM(UTC)
misterfixall
it may be board ,check wires connected to heater ,sometimes they will burn
Dave Turman
#3 Posted : Friday, July 25, 2008 11:37:08 AM(UTC)
Dave Turman
Thanks so much for the help. I will check the connections on the element.let you know what I find.Thanks again.
