kimmitchell
#1 Posted : Friday, July 25, 2008 8:41:43 AM(UTC)
kimmitchell
My front loader washing maching will turn on but the door won't lock and start to fill with water. ANY IDEAS?!:confused:
kimmitchell
#2 Posted : Friday, July 25, 2008 8:43:04 AM(UTC)
kimmitchell
Kenmore front loader washer has power, but the door won't lock and start.
#3 Posted : Friday, July 25, 2008 8:52:04 PM(UTC)
Does it show any error code?
Can you be more specific on the problem?
kimmitchell
#4 Posted : Saturday, July 26, 2008 9:31:44 AM(UTC)
kimmitchell
No, there isn't any error code. It looks like it always does when I turn it on. The door just won't lock so it will start.
On this model I have to hold the start button down about 3 seconds then the door locks and begins. But I hold it down...and nothing.
#5 Posted : Saturday, July 26, 2008 1:15:06 PM(UTC)
Most likely the problem is a bad control panel but there is a small chance that the CCU can be bad too.
In order to provide the right part number for the control panel I need the color of it.
kimmitchell
#6 Posted : Saturday, July 26, 2008 5:31:57 PM(UTC)
kimmitchell
It's white. Could it be a faulty door lock?
#7 Posted : Saturday, July 26, 2008 6:50:02 PM(UTC)
The CCU in your washer has a self diagnosis abilities and if there is something wrong with the door latch, it should show an error code on the display. Look for the tech sheet inside the control panel or behind the bottom panel.
#8 Posted : Saturday, July 26, 2008 6:53:32 PM(UTC)
The part number for the white control panel is AP4260739
kimmitchell
#9 Posted : Sunday, July 27, 2008 9:58:25 AM(UTC)
kimmitchell
Thanks so much for your help!
