ronniestewart
#1 Posted : Thursday, July 24, 2008 9:46:37 AM(UTC)
ronniestewart
I have a hotpoint gas range that is run off propane gas. i just recently purchased a new burner with ignitor and a gas safety valve. now when i turn the oven on , the flame is huge and coming up into the oven. as before i had a very small flame. what could cause this problem. the oven reaches temp and the gas cuts off. Is there any way to adjust the flame on the burner?
abadfish66
#2 Posted : Thursday, July 24, 2008 10:02:04 AM(UTC)
abadfish66
Did you convert the new burner and safety valve to lp, they come set up for natural gas, so you need to change it.
ronniestewart
#3 Posted : Thursday, July 24, 2008 10:13:15 AM(UTC)
ronniestewart
how do you convert it to LP
abadfish66
#4 Posted : Thursday, July 24, 2008 10:34:58 AM(UTC)
abadfish66
on the safety valve, there is a brass plug, unscrew it and inside is a plastic piece that needs to be turned around.
Guest (4)
