clfry
#1 Posted : Wednesday, September 29, 2010 8:18:50 AM(UTC)
clfry
In order to move my washer where I can work on it, I need to first drain it... I'm guessing there has to be a way to bypass controls/switches (ie: with a jumper wire, etc) to start the drain process, is there?
clfry
#2 Posted : Wednesday, September 29, 2010 10:03:02 AM(UTC)
clfry
Sorry, the model # is actually lsn1000kq0
magician59
#3 Posted : Wednesday, September 29, 2010 1:40:14 PM(UTC)
magician59
By removing the drain hose from the drain stand pipe, and lowering it to a level below that of the water in the tub, a large portion of the water will siphon out.
clfry
#4 Posted : Thursday, September 30, 2010 7:24:21 AM(UTC)
clfry
So there's no way to start the pump/drain process manually to drain it normally? I need it to be empty in order to move it to drain it, lol
magician59
#5 Posted : Thursday, September 30, 2010 7:50:04 AM(UTC)
magician59
If you don't mind getting wet, you CAN tilt it back and dis-connect the larger of the hoses from the pump. That'll empty it really fast.
clfry
#6 Posted : Thursday, September 30, 2010 10:03:23 AM(UTC)
clfry
Nevermind, I rigged the switch to get it to drain.
